Puch Cobra - Help Cylinder
Aljaxon
hola!
i hope someone speaks english.
i have a 6 speed puch cobra 50 aircooled engine and cannot find any information or specifications. this forum is excellent but i dont read spanish.
i need a new cylinder/piston. i would like to go to 70 or 80cc
do any of the metrakit gilardoni airsal etc top end kits fit the cobra?
does the 74 or 80cc cobra cylinder fit the 50 cc engine? are the cranks the same stroke?
i have a metrakit fitted to my puch m50sport but it wont fit the cobra, the cobra studs are spaced 56mm apart. the m50sport studs are 45mm
the cobra wasnt sold in england so there are no spares or info. can you get second hand cylinders and re bore them or re plate them?
are there any cobra cylinders with cast iron bore? cheers
cheers
alan
cheers
alan
Aljaxon- Usuario Nuevo
Re: Puch Cobra - Help Cylinder
Hello.
for motor 6v charges. here you will find what buescas without any problem and I do not understand English ablo. but there taduccion, select what you want to translate and translates the program,
Greetings Angel.
tengo un puch cobra 49cc
que el cilindro se ajusta cobra?
gilardoni metrakit airsal ?
me gustaría algo de comida
me gustaría 73-80cc.
¿tiene esto sentido?
hello, in spain there´s only cylinders for the model 75cc, not of auxiliary industry, just OEM, in sales pages sold sometimes some, maybe you find one in this forum in the market section, but you need learn spanish,
greetings.
greetings.
Hi Aljaxon, first of all, welcome.
As you can see, it´s dificult to comunicate and explain tecnical issues in english, but i will do my best.
In Spain, the auxiliary industry for puch cobra cylinder/engine does not exist, also in the past. All the cylinders are originally from puch.
There are cylinders of 70cc that fit on 337-50 engine (air cooled) and 80cc that fit in 337-80 cylinders (water cooled). The engines are the same always (stroke, connecting rod, etc).
If you want to go up from 50cc to 70cc, you can buy a second hand cylinder in Spain and re bore to the size of the piston (48,5mm). The bore in Spain is iron and the standard size is 48mm.
You can find pistons in the spanish ebay ("piston puch cobra" i think the cost it´s arround 50 euros).
Maybe you can include some photos of your puch in your next answer? Welcome again!.
Best regards,
Guillermo.
Best regards,
Guillermo.
GMLeon- Usuario De Élite
thanks for your reply GMLeon. i have a cobra 49cc engine and i want to fit it into my puch m50 sport (m50 racing).
the m50 sport has a 73cc metrakit fitted but the stud spacing is different.
i will take some pictures tomorrow.
i dont mind buying a damaged cylinder and getting it re-sleeved or re-lined as i can do the porting myself.
thanks
alan
thanks
alan
Pero dejadle que el traduzca y hable en castrelleno, mas bien para que todo el mundo se entere.
Saludos Angel.
Saludos Angel.
Seria lo mas acertado ya que la mayoria no sabemos de que va el pos
Esto dice Aljaxon.
gracias por su respuesta GMLeon. tengo una cobra 49cc el motor y quiero encajarlo en mi puch m50 el deporte (m50 compitiendo con).
el deporte de m50 tiene un 73cc metrakit empotrado pero el espaciado de tachón es diferente.
tomaré algunos cuadros mañana..
Muchas gracias 2000rpm,
Necesito un clynder de 80cc y cabeza para el cobra
Buenos dias Aljaxon.
Aqui te dejo un enlace directo.
http://mototema.com/tiendas/product_info.php?cPath=45&products_id=3207
Saludos Angel.
Saludos Angel.
Revisé y su nuevo.
¿parece caro?
¿es este precio normal?
¿parece caro?
hola.
El problema es que no es facil localizar cilindros de cobra nuevos. o equipo motor tanto de agua como de aire.
Si tienes paciencia y sigues el foro puedes localizar usados para reparar.
Pero ya digo con paciencia,- No es facil.
Saludos Angel.
Saludos Angel.
¿tengo a máquina el cárter del cigüeñal 49cc?
para montar el cilindro 80cc?
Aljaxon escribió:¿tengo a máquina el cárter del cigüeñal 49cc?
For a better translation please write frist in spanish and then in english
Para una mejor traducción por favor escribe primero en español y luego en ingles
OK gracias va aquí
ok thank you here goes
¿tengo el cárter 49cc para montar el cilindro 80 de la máquina
do i have to machine the 49cc crankcases to fit the 80cc cylinder?
Yes, you do. The bore of the cylinder is biger and the "neck " is a bit biger, maybe only 2 mm, and it mean that, you have to open the crankcases in the top, just where the cylinder connect with the crankcases.
Aljaxon pregunta, si tiene que mecanizar los carteres para acoplar un cilindro de 80cc en uno de 49cc, y le respondo que si, que el cuello del cilindro es un poco mas grande y hay que abrir un poco los carteres.
thats ok
i did the same to my puch m50 sport to fit the metrakit cylinder
eso es aceptarhice lo mismo a mi deporte m50 a montar el cilindro
thanks for the help
Gracias por la ayuda
thanks for the help
Se tendria que comprovar la carrera de la biela, para ver si es la misma que la cobra de 75cc.
Yo pienso que es la misma carrera.
Estos motores estaban diseñados para 50cc. y en España se transfomavan y se subian a 75cc.
Pero abria que comprovar las medidas.
Saludos Angel.
Saludos Angel.
i will need to get a cylinder firstand then measure.
se obtiene un cilindro primera entonces medir lo que necesito.
i can always fit a longer or shorter conrod
siempre puedo colocar una biela más o menos
gracias
gracias
t
Traduccion.
i tendrá que obtener un cilindro firstand luego medir.
Se obtiene sin cilindro de primera 'entonces' Medir Lo Que Necesito.
i siempre puede caber una biela más larga o más corta
Siempre colocar PUEDO MÁS Una biela o Menos
gracias
gracias
Buenas.
La carrera de los motores de cobra es de 39,7mm.
Si esto es asi pues nada compras el equipomotor de 400 Euros y las juntas y a montar.
Saludos Angel.
Saludos Angel.
uso bing traductor y no es muy exacta
i use bing translator and its not very accurate
gracias 2000rpm
gracias 2000rpm
sorry i dont understand this using bing
lo siento!; no entiendo esto con bing
» cobra 80 cilindro refrigerado por aire - cobra 80 air cylinder
» Puch Cobra - Diferencias Chasis Replica VS Cobra TT
» Puch Cobra MC 75 - Donde Estará Mi Antigua Cobra
Ayer a las 19:11 por JOSEBU
» pegatinas de carabela super
Vie 2 Ago 2024 - 14:30 por Manu_e90
