Puch Cobra M-82 - Building A Replica Frame
Puch Cobra M-82 - Building A Replica Frame Empty Puch Cobra M-82 - Building A Replica Frame
Mensaje por Mechanic Dom 7 Feb 2010 - 21:23
Hello everybody,
my son and I think it's almost impossible to buy a frame in Spain, get it here and modify it in time, so we can race it in the moped-cross this season. So we want to build one ourselves, from scratch. It's not a problem if it's not 100% identical to the real ones but we want to build one very close to the original thing.
What we are looking for are drawings of the frame, maybe someone has them?
If not, measurements from bend to bend and ofcourse across the frame, are needed to make a good drawing. Eventually assisted with angles of the bends. Also tube diameter and wall thickness are welcome.
I have to change some things because the engine (E30 1-speed) we use this year, has a longitudinal cylinder which sits more to the left on the engine, as opposed to the 6-speed. We're lucky it's a watercooled cylinder so it's rather small from side to side.
Here are some pictures with numbers on them, followed by a list with numbers from which I would like to know the distances.
Puch Cobra M-82 - Building A Replica Frame Puchcobram82framemeasur.th
1-4, 1-7, 4-5, 5-6, 5-7, 5-8, 5-9, 8-10, 8-11, 8-12, 8-13, 9-10, 10-11, 11-12, 3-12 and 2-13.
Puch Cobra M-82 - Building A Replica Frame Puchcobram82framemeasura.th
13-14, 13-17, 20-22, 22-22a, 23-24, 25-27, 26-28, 29-30, 31-32, 33-34 and 17-33.
Futher more, the diameter and length of the steeringheadtube, angle: A, thickness of B, C, D and E, and the height of E above the reartubes.
Anyone willing to do the measurements, can send their list to my email, or ofcourse put it here.
Hopefully we'll get a responce soon.
Greetings, Joop
Edit: the dots are on the middle of the tubes and in the middle of the bends.
Última edición por Mechanic el Dom 7 Feb 2010 - 22:36, editado 1 vez
Mechanic
Mechanic
Puch Cobra M-82 - Building A Replica Frame Empty Construyendo una replica de un bastidor de puch cobra M82
Mensaje por PerezVera Dom 7 Feb 2010 - 22:17
Hola a todos,
mi hijo y yo creemos que es casi imposible comprar un chasis en España, lo conseguimos aquí y lo modificariamos con tiempo, así que puede correr en moto-cross esta temporada. Así que queremos construir uno nosotros mismos, desde el principio. No es un problema si no son a 100% idénticas a las reales (medidas chasis), sino que queremos construir uno muy cercano a lo original.
Lo que estamos buscando son los dibujos del chasis, ¿ tal vez alguien lo tiene?
Si no, las mediciones de las curvas, y por supuesto en todo el chasis, son necesarios para hacer un buen dibujo. Finalmente, tambien ayudan los ángulos de las curvas. También diámetro del tubo y espesor de la pared son bienvenidos.
Tengo que cambiar algunas cosas porque el motor (E30 1-velocidad) que utilizamos este año, va longitudinal el cilindro que se encuentra más a la izquierda en el motor, a diferencia de la de 6 velocidades. Tenemos suerte de que es un cilindro refrigerado por agua, por lo que es más bien pequeña de lado a lado.
Aquí hay algunas fotos con los números de ellos, seguido por una lista con los números de la que me gustaría saber las distancias.
Cliquea sobre la imagen para verla mas grande
1-4, 1-7, 4-5, 5-6, 5-7, 5-8, 5-9, 8-10, 8-11, 8-12, 8-13, 9-10, 10 -- 11, 11-12, 3-12 y 2-13.
13-14, 13-17, 20-22, 22-22a, 23-24, 25-27, 26-28, 29-30, 31-32, 33-34 y 17-33.
Adicionalmente, en el diámetro y la longitud de la pipa de direccion, ángulo: A, el espesor de B, C, D y E, y la altura de E por encima de lo tubos traseros.
Cualquier persona dispuesta a hacer las mediciones, puede enviar su lista a mi correo electrónico, o por supuesto ponerlo aquí.
¡ Esperamos poder obtener una respuesta pronto ¡.
Saludos, Joop.
Nota: los puntos están en el centro de los tubos y en el centro de las curvas.
Última edición por Perezvera el Dom 7 Feb 2010 - 23:20, editado 2 veces
Puch Cobra M-82 - Building A Replica Frame Empty Re: Puch Cobra M-82 - Building A Replica Frame
Mensaje por Mechanic Dom 7 Feb 2010 - 22:33
Hello Perezvera,
maybe it's a good idea for me, to put a translation in Spanish under my post.
Thanks for this one! Alabado
Joop.
Hola Pérez Vera,
Tal vez sea una buena idea para que me ponga una traducción en español con mi puesto.
Gracias por esto! Alabado
Joop.
Mechanic
Mechanic
Mensaje por PerezVera Dom 7 Feb 2010 - 22:38
Espera joop que todavia no he "acabao". Carcajadas
Muchos greeting. Bien
Mensaje por PerezVera Dom 7 Feb 2010 - 22:49
Por lo que he podido entender, este compañero quiere realizar una replica de un chasis de M82, para asi montar un motor de cilindro horizontal y que corra su hijo con él en motocross.
¿ Hay alguien que tenga un chasis o bastidor (frame en ingles) que lo tenga "pelao" y pueda hacer las mediciones que joop solicita ? (las expecifica en la foto)
Puch Cobra M-82 - Building A Replica Frame 10foutc
Puch Cobra M-82 - Building A Replica Frame 205cw0i
Seria de gran ayuda, bueno para él, y asi lanzaria este foro a una proyeccion de momento europea, Carcajadas con aspiraciones para alcanzar un nivel mundial. Carcajadas Carcajadas , bueno quien sabe, la cosa es que hay ambiciones para alcanzar esta meta. Risa
¡¡ Joop ¡¡, como puedes ver en el siguiente enlace, aqui tienes a la venta un chasis de M82, su precio como puedes comprobar es barato.
Yo quisiera conocer si te seria interesante para ti joop, realizar gestiones en Holanda para encontrar una empresa que realice el transporte de este chasis y por que precio.
Las gestiones de la compra de este bastidor las hariamos nosotros desde España.
Joop, you see the link below, here's the M82 chassis sale, its price is cheap as you can see.
I would like to know if you would be interesting for you joop, safeguarding in Holland to find a company that transports this chassis and for what price.
Efforts by the purchase of this frame would make us from Spain..
http://www.lamaneta.org/mercadillo/ventarecambusuario.cgi?movil=puchmoto@yahoo.es&num=5933
Muchos greetings campeon.
Última edición por Perezvera el Dom 7 Feb 2010 - 23:25, editado 1 vez
Mensaje por PerezVera Dom 7 Feb 2010 - 22:57
¡ Volvere ¡
No sus vayais ehhh.
Mensaje por Mechanic Dom 7 Feb 2010 - 22:58
Sorry, but Google doesn't translates "acabao"?? Consolado
Lo sentimos, pero Google no se traduce "acabao"?? Consolado
Mechanic
Mechanic
Mensaje por Mechanic Dom 7 Feb 2010 - 23:02
Google say's : Todavía no somos capaces de occitano en la traducción neerlandesa. Ooops!
Mechanic
Mechanic
Mensaje por PerezVera Dom 7 Feb 2010 - 23:06
Mechanic escribió:Sorry, but Google doesn't translates "acabao"?? Consolado
Menuda putada, con lo mal que hablamos los andaluces. Demonio
Pero tranquilo joop que no es ninguna cosa mala.
Vergüenza Tímido
Mensaje por Mechanic Dom 7 Feb 2010 - 23:19
El problema con Google-traducir es que sólo se traduce única lengua oficial. Toda la jerga, dialecto o lenguaje de MSN y Google se ha perdido.
Campeón (que es su nombre?) Me gustaría saber lo que los gastos de envío (correo?) Costaría. También sé camionero (originario de España, pero viven en Holanda desde hace mucho tiempo) que se utiliza para conducir a España mucho, le preguntaré si él también tiene que ir a Madrid (en breve).
Saludos, Joop.
Mechanic
Mechanic
Mensaje por PerezVera Dom 7 Feb 2010 - 23:24
No joop, es un nombre cariñoso.
campeon = champion.
Muchos (very) greetins champion. Bien
Mensaje por Mechanic Dom 7 Feb 2010 - 23:39
Ah, bien, Ooops! y sobre la que el campeón, eso es lo que esperamos que en esta temporada.
Ahora voy a tomar una Beber e ir a Dormir, tengo que trabajar mañana temprano.
saludo, Joop.
Mechanic
Mechanic
Mensaje por Mechanic Lun 8 Feb 2010 - 10:25
I wondered if anyone knows the weight of the frame, without swingarm, tank etc etc?
Greetings, Joop
Me preguntaba si alguien sabe el peso de la trama, sin basculante, tanque, etc etc?
saludos, Joop
Mechanic
Mechanic
Mensaje por PerezVera Mar 9 Feb 2010 - 17:37
Mensaje por PerezVera Mar 9 Feb 2010 - 22:41
No hay "naidien" que tenga un chasis "pelao", para dar pesos del chasis, medidas y esas cosas.
Me gustaria poder ayudar a mechanic en lo que buenamente se pueda.
Mensaje por MotorVilaPuch Miér 10 Feb 2010 - 10:09
Yo tengo un chasis de M-82 pelao.
No tengo en qué pesarlo, pero calculo unos 25-30kg, nose.
Hay que repararle alguna cosilla, pero si no aparece otro, yo puedo poner ese.
Tengo que hacerle fotos, porque tenía fotos, pero no las encuentro.
Mensaje por PerezVera Miér 10 Feb 2010 - 14:53
A razon de tu palabras David tengo que comentar al respecto.
Esta mañana he estado en correos preguntando sobre el tema de remitir paqueteria a los Paises Bajos. En principio si existe la posibilidad de remitir paquetes al extranjero y en particular a Holanda. Por aqui no problemo.
El problema viene ya que el paquete no puede medir mas de un metro de largo / alto. Mas o menos por peso no hay problema. Hay unas tarifas fijas y luego unas variables segun valor que tu des al paquete, peso ect., y todo esto te da un precio por remision de un paquete al extranjero, en este caso el chasis del que estamos hablando, no se si me he equivocado pero he entendido que para un peso de 15 kg me ha dado un precio de alrededor de 80 €.
Otro inconveniente de todo esto es por el tema abono de esta venta. No admiten contrareembolso en este tipo de paqueteria.
Repito que si el chasis mide mas de 1 metro largo/alto no se pude remitir, asi que ruego david si te es posible medir el chasis para ver si esta dentro de estas cotas. Digamos que con esta condicion se puede efectuar el envio.
Asi que no es por quitarme de el medio David, pero pidele a joop un precio de venta por tu chasis (caso que desees venderlo en este momento), mas el precio del envio y a ver te contesta si desea o no que se realice la operacion. Si encuentras fotos y se las puedes como has citado pues casi que mejor.
Luego viene lo mas peliagudo, el pago del chasis, te tendria que hacer un ingreso o un giro por el dinero que estamos tratando por digamos esta operacion.
Esto es lo que hay, como he dicho y como siempre no quiero mal entendidos ni cambios de versiones despues.
Mechanic se ve que tiene prisa por conseguirlo por la cantidad de correos privados que me manda, pero poco puedo hacer yo si no tengo ningun chasis a la venta y el unico que he visto esta en madrid, y dudo mucho que el vendedor quiera meterse en este jaleo de mandar nada al extranjero.
La verdad es que con tiempo se podria buscar una opcion para mandar el chasis, pero todo esto en unos dias y con la "sin titulacion" que tenemos es para soventar estos problemas es complicado, la verdad.
Un saludo y gracias. Bien
Mensaje por Mechanic Miér 10 Feb 2010 - 17:11
ola a todos,
Antonio acabo de hacer una estimación aproximada, y creo que una M-82 marco es demasiado largo mar una M-82 C sólo podría interior de la longitud de 1 metro se mantendrá. Si esa es la última pieza se reduciría de allí. (1 menos problema)
El pago de los Países Bajos no pueden ser un problema. Una vez compré un botón para una marcha en Portugal y la banca por Internet está ahí, así que ¿por qué no en España?
Tiempo para mí sólo la cuestión del peso. Que debo saber lo que un solo fotograma pesa, sin basculante, tenedor y el tanque.
Así que será difícil, pero quién sabe.
Ya tendría que ir a través de los dibujos en mi computadora, en caso de que todavía tienen que hacerse de un marco.
Tal vez por la información. Las fotos que he publicado demasiado pequeño como para ser lo que los puntos y números. Si hace clic sobre la imagen y luego abrirlo en Imageshack, ya se puede ver mejor, pero si haces algo aumenta (parte inferior derecha de la pantalla hasta un 200% por ejemplo), entonces usted ve los puntos y los mejores números.
Si hay preguntas acerca de algo, me gusta esa respuesta.
Haga clic en la imagen para verla más grande
Puch Cobra M-82 - Building A Replica Frame Puchcobram82framemeasurb.th
Aún soy muy tímido para el tamaño adecuado y sería muy feliz si alguien se toma la molestia de los tamaños necesarios para mi medida.
Saludos, Joop.
Mechanic
Mechanic
Mensaje por PerezVera Jue 11 Feb 2010 - 21:20
Tan solo pregunto ¿ hay algun avance ?.
Mensaje por Invitado Jue 11 Feb 2010 - 22:00
Mandarle el chasis en pedacitos y que luego lo suelde Puch Cobra M-82 - Building A Replica Frame 399865
Anonymous
Invitado
Invitado
Mensaje por PerezVera Jue 11 Feb 2010 - 22:56
Que cosas tienes "Oze", aunque la idea no es mala .Risa
El problema viene que yo no tengo ningun chasis, el que lo tiene dudo que este dispuesto a empaquetarlo para mandarlo a Holanda. Asi que estamos un poco parados, pero este compañero holandes se ve que tiene prisa por conseguir el chasis, se ve que por alli tambien llueve mucho y tiene tiempo en estas fechas.
Un saludo campeon. Feliz
Mensaje por Mechanic Jue 11 Feb 2010 - 23:06
@ Antonio, lamentablemente, no hay progreso, nadie tiene una lista de las dimensiones requeridas enviada por correo a mí. En marzo, un destacamento de la Fuerza Aérea de Albacete para la formación de las tripulaciones, a lo mejor puede tener un tanque, un guardabarros delantero y trasero y protectores laterales para mí, pero no vuelvas hasta finales de marzo. Demasiado tarde para un cuadro, yo no tendría tiempo para construir la cruza.
@ Joselitro, ja, ja, broma agradable, pero veo que usted me puede ayudar porque tiene un Cobra M-82. ¿Te gustaría medir las dimensiones, que he mencionado en este tema, entonces puedo terminar mi dibujo y empezar a construir mi marco.
Estaría eternamente agradecido.
Saludos, Joop.
Mechanic
Mechanic
Mensaje por Invitado Jue 11 Feb 2010 - 23:59
Hi Joop.
Lend me this weekend and tell you something.
Anonymous
Invitado
Invitado
Mensaje por Mechanic Vie 12 Feb 2010 - 1:10
Joselitro, you would make me very happy and if you have any problems with it, please let me know so I can explain.
Greetings, Joop.
Joselitro, se me haría muy feliz y si tiene algún problema con ella, por favor hágamelo saber para que yo pueda explicar.
Saludos, Joop.
Mechanic
Mechanic
Mensaje por MotorVilaPuch Vie 12 Feb 2010 - 10:23
Mañana (si la nieve lo permite), voy a acercarme a casa de un colega, a por el chasis que decía. Espero que aún lo tenga.
Tenez un poco de paciencia. Bueno
Me lo traigo, le hago fotos y a ver que os parece.
Perezvera, vas a tener que hacer un poco de intermediario, jejeje, si acaso Joop quiere el chasis, a ver si me mandas su dirección y me comentas como va el tema del transporte, porque yo ando bastante liadillo y tampoco tengo coche ahora mismo para desplazarme muy lejos. Triste
